Swap different brands of pads
Anyone here swap two different brands of pads for street/race on the same set of rotors? Any thoughts on that?
Do you bed in the pads on every swap, or only the first time they're used?
For the people that are against that, do you have two sets of rotors for street/race that are mated to their pad?
Do some people swap, but run the same brand of pads for street and race as recommend by some pad manufacturers?
I'm preparing my car for doing track days, and am trying to figure out a brake solution. I want to run full race pads on the track, but it would be great to keep my OEM pads for the street. They have tons of life left, and I don't want any extra rotor wear, noise, or dust on the street.
What is the most rotor friendly race pad?
Searching around, I've found these race pads:
Carbotech XP8 or XP10
Cobalt ??
EBC Yellow stuff
Porterfield R4
Hawk Blue 9012 or HT 10
Any of the above have a street pad that is equal or better than OEM at rotor wear, noise, and dust?
Thanks.
Cobalt ??
EBC Yellow stuff
Porterfield R4
Thanks.
All of those things work. None of them work perfectly.
Not necessary to change rotors or to re-bed with change of pads. If anything the street pads have more bite after running the track pads on the same rotors. But I strongly recommend getting full race pads for track and OEM pads for street. I like the Hawk HT10 front with Hawk Blue or Black rear.
So we have a couple votes for it being OK to run OEM and race pads on the same rotor.
Anyone believe that it is better to run street and race pads from the same manufacturer? Or is this just marketing propaganda.
I don't mind the extra work of changing the rotor, just the extra cost. I want to get rotor friendly race pad too.
I might go to this method...and it's much easier to swap JUST the pads. I would guess that would save me about 30 mins of time by not having to pull off the entire caliper.
I was swapping rotors for a while -- not because I was worried about the pads but because my rotors were getting eaten up by the track and I wanted to be sure I had a good, safe set of rotors on the car for the street.
If they will stop you on the track with R-compounds and race pads they will stop you on the street .
I usually worry the other way around.... I'd be comfortable with old worn hair-line cracked rotors on the street but more concerned about them on the track.
