Suspension upgrade or something else?
#21
I run +63 17x9s with 3.5 degrees of camber. Yes they rub the control arm at full lock....but ask yourself...how often do you go to full lock? I just don't go to full lock anymore. If I'm really tight in a parking lot or whatever I'll just turn to full lock and then back off very slightly so I'm just off of full lock. When you're racing you'll never turn the wheel more than 1/2-3/4 turn max so it's definitely not a concern then.
I am lowered a couple inches, and all I did was bend the tabs on the inside of the fender in front...no fender pulling or anything like that and I didn't even touch the rear fenders.
I am going to add a small spacer to help with rubbing on the part of the fender over the inside of the tire at maximum compression - but you shouldn't have that problem if you're not lowered
So that's what I'd recommend. And a nice front sway bar.
#22
Originally Posted by odb812' timestamp='1346096617' post='21968438
To give you an idea, I just got 4 17x9 +62 TR Motorsports C3 wheels from tirerack for $650. They don't look bad, they're not heavy, and I haven't rolled my fenders yet. It doesn't look like I'll need to, but I'm going to before my next track day just because it would suck to find out I need them rolled between sessions that I've already paid for.
#24
Originally Posted by psychoazn' timestamp='1346098501' post='21968550
[quote name='odb812' timestamp='1346096617' post='21968438']
[/quote]
Anything Rays Engineering.... but $$$
And yes, you should be fine.
NewScooby
02-19-2010 12:13 PM
David NJ
02-27-2004 04:15 PM
