View Poll Results: What tires (primary) do you use?
Toyo R1R 245
0%
Toyo R1R 255
0%
Voters: 225. You may not vote on this poll
STR Prep - Wheels and Tires
#411
So for you RS3 guys, when do you find that start "falling off" or heat cycling out? I have over 50 runs on mine so far and they still seem pretty good.
At the last event I did feel that they were overheating though. Do they need to be sprayed down? My morning three runs were my fastest (unusual for me, ha), and the afternoon runs were about .5-.8sec off of that pace. It was a sunny day in the high 70s-mid 80s on a grippy concrete runway.
#412
Originally Posted by JiminVirginia' timestamp='1367936612' post='22524894
Set up Question
The poll at the top of the thread suggests at least a few guys are running a square set up using Enkei Racing PF01 (17x9 +60) with 255/40/17 tires.
Any fitment issues? Does this work in front as well as rear?
(I'm a new s2000 owner, previously running a ZO6. I'd appreciate any advice.)
Jim
Jim
#413
I myself sold my RS3 tires after 100 runs as I felt they started to hear cycle out or fall off slightly. Selling them for half price meant 2 sets of tires a season all good tread at the cost of one set of tires
We shall see how the rivals turn out
#414
Originally Posted by nmrado' timestamp='1367938911' post='22524979
[quote name='JiminVirginia' timestamp='1367936612' post='22524894']
Set up Question
Jim
Set up Question
Jim
[/quote]
Ride height. Up in the 13.25", maybe 13", range you don't need to roll, or if you have narrower tires/wheels. At my ride height (12.75") with my soft-ish suspension the tabs have to be bent up.
Also I think you'd be surprised, pretty sure most are rolled.
#415
Ride height is part of it. What will happen is you will hit a particular bump while the wheel is turned out and it will pull the fender. Or you will get into a counter steer when your back end breaks loose in a high speed sweeper. The car will be fully loaded up on the outside front tire and it will pull the fender out. It's just a matter of time. This is a repeat story for many over the last few years.
If you are going to run 255s up front then get to the fender rolling before the fender gets pulled out by the tire.
Typical Pattern
Pulled fender after high speed counter steer after which the fenders got rolled.
Start of liner wear near outer edge
Here's the rolled fender and how much of the fender liner will be gone. I ended up cutting the hanging pieces out on each end.
Typical Pattern
- Denial - Drive for a while and do nothing until you hear some rubbing.
- Partial Acceptance - Bend the fender tab back because the tire gets shaved, part of the fender liner gets worn away.
- Full Acknowledgement - Roll the fender because it pulled out on a bump or high speed counter steer.
#416
Been reading this thread with interest. I've been running competitively at local events in STR with a mostly stock set up. I have AP2 wheels, 225/255 tires, Eibach Pro Kit springs and sway bars on an AP1. (Rear bar currently disconnected.) I do not plan to do the full STR prep, but would like another set of wheels and tires. I'm thinking of trying 17x9 +63 with 245/40 BFG Rivals square. The car currently sits at 13". Can I get away without rolling the fronts? Or will the softer springs give me problems?
Thanks, Mark
Thanks, Mark
#417
Typical Pattern
GREAT POST, BTW!!
#418
Thanks, Mark
Thanks, Mark
#419
I'm convinced the S2000 handles better at a higher ride height (close to OEM). My AP1 is approx 4.75-5" (after corner balance) from a level surface to the jack points (unbent/good condition). I have confirmed this now on 2 cars (AP1 and AP2) and looking for more willing to try my settings and let me drive. What we though about bump steer and the angles of the rear control arms doesn't translate to actual driving behavior on an autox course. That said and to make this point relevant to the topic, why lower your car and deal with these fender clearance issues? This may even allow for some more aggressive offsets.
-Marc
-Marc
#420
-Marc
-Marc
