View Poll Results: What tires (primary) do you use?
Toyo R1R 245
0%
Toyo R1R 255
0%
Voters: 225. You may not vote on this poll
STR Prep - Wheels and Tires
#263
Depends on ride height. At stock-ish height you wouldn't have any issues with camber on the lower spectrum of what we typically run. Slammed as low as my car is (12.25" front/rear from wheel center to fender or 3.25" from pinch welds to the ground F/R) you'll have to run "alot" of camber to clear the fenders. I run -3.0 front and -2.7 rear and daily drive my car everyday. During the season I daily my race tire also. Haha the wear isn't that bad at all. Here's a picture of some tires I was dismounting to put on new ones.
You wouldn't have any problems with proper sized STR wheels rubbing. Key word "proper" (17x9 +60-63)
Good luck with your autox goals, it's very addictive if your a competitive person like myself. I'd race every weekend if I could. speaking of which I have do much stuff to do this off season. Haha
#264
Thanks for the advise. The car is currently on stock suspension but I plan to drop it an inch. This car has to pull triple duty: HPDEs, autocross and not piss off the wife. My Civic fit 2 of these duties well but the wife would not go to dinner in a 246 whp slammed Civic, go figure? So I need to keep this S2000 somewhat wife friendly. You got that right about autocross being addictive. When I started back in the early 90s I was going to an autocross most weekends but then I went hillclimbing and ran time trials and the autocross events were put on the back burner. Now I want hone my driving skills with the S2k. I just picked up a wicked set of shocks and am hoping I can make the staggered Volks work for the year. Is it true if you are running a stockish front tire you really don't need the $1,000 front bar? I hope so as $1k for a single sway bar is hard to justify. But the nice thing about asking advise is that it can save you tons of money spent on inadequate parts.
#265
The big three are Tires, Swaybar, and alignment. A swaybar from small fortune racing is something ike $660 for a 1.25 hollow bar. You'll want to run it on full stiff. These 3 mods will get you half way there. I proved this last national tour I was at by running my friends CR in RTR with very minimal prep and ran first heat. My winning times where good enough to do very well in STR and they even ran in a later heat with warmer weather. Point is- don't cheap out on the parts that are must haves, the big 3. The rest is for that last little bit that could win a race thats really close.
#267
You can search on here and find a ton of info on the miata bar. It does work great and I ran it for quite some time. Matched with the 1.25 hollow on full stiff setting the front/rear balance should be pretty good depending on the rest of the setup. I found that with my 1.25 solid bar on full stiff I was wanting alittle more rear bar for balance purposes. Therefore I ended up with the gendron ball bearing rear bar. Kind of expensive but "because racecar" you know? The 1.25 hollow/miata bar setup should work well together.
#269
The only caveat is you probably want to roll up the fender tabs in the front to be safe.
#270
Thanks that sounds like the way to go. I guess I may need to sell the Volks. Unless I can figure out how to keep 3 sets.
Random1: sorry for getting off topic with the sway bars. I have read the discussions that you referred to but a lot of what is said can be all over the place and getting first hand opinions on set-up is invaluable. I will be topic specific in the future.
