STR Prep - Suspension and Alignment
#31
Powerflex looks to be $444 not counting the $88 mugan bushing. I'm not sure what number 3 is on the powerflex website though.
http://store.powerflexusa.com/honda-...hings-p75.aspx
Thats alot cheaper then both OEM and Mugan. I might just do the powerflex and what bushings I can't do have my cousin do.
#32
I believe three is the bushing where the damper mounts to the rear arm. I didnt get that one or the sway bushings (my bar came with new poly bushings.) I got everything else they had.
#34
My front lowers squeek. Haha. Its annoying. Silicone spray lasts for about a day. I antiseized the bolts and lubed the bushes on install too. I just ignore it, and hope the competition thinks my cars janky.
#38
Toe in or zero toe is what most people go with. Toe out in the rear would make the car VERY loose. Zero toe it is still going to be a bit loose depending on setup. Toe in makes the rear more stable.
#39
My specs
Car: 2001 S2000 AP1
Weight: ???
Ride height: 13"f/13.5"r hub center to metal fender edge
Springs: 515f/515r (KW v3)
Front Bar: Saner FSB 3rd hole
Rear Bar: Stock
Alignment: -1.2f, -2.6r camber, 0" toe front, 1/16" rear toe-in
Tires: 255/40/R17 Hankook RS3 [square]
Wheels: C3 TRMotorsports 17x9 offset +63
Bushings: OEM (83k miles)
Also have Megan front BSK shims, Megan rear BSK toe arms, and Megan roll center adjusters (not STR legal apparently)
#40
