STR Prep - Suspension and Alignment
#381
Sorry if this has been asked and answered already (I skimmed every page in this thread but could have missed it): how much camber can you get at a moderate ride height (say 13" hub center to fender) *without* a camber kit?
I'm thinking about doing a low budget STR build, and am wondering how much I'd be giving up if I skipped a kit.
Thanks!
Edit: I can get between -1.8 and -2.0 degrees at stock ride height, depending on the rack and the day.
Thanks!
#382
Thanks!
Thanks!
#384
Anyone done good testing on camber settings for the Rivals? I'm -3.1F/-2.7 rear and the insides seem to be wearing quicker then the outsides. I do drive the car on the street some so I'm not 100% sure if my wear is slightly inaccurate because of that.
So to get less than -2.7 in the rear I'd have to raise the car up. Question is how much do I have to raise it to get .2 less degrees? Anyone know?
#385
https://www.s2ki.com/s2000/topic/802...#entry19100186
#386
Thanks!
Thanks!
#387
Anyone have thoughts on the Eibach Multi Pro R2 Coils with 650 F 650 R spring rates? Picked those up and wondering if the square setup will be ok to start with. Other mod would be either the Moddicitions or V2 adjustable bar so I would be able to get some high rates to compensate up front. Never ran square before and hope its going to be ok to start with.
#388
Sent from my SAMSUNG-SGH-I747 using Tapatalk
#389
While it is purely theoretical, you can get a general idea of car balance with roll rate biases. Per a discussion with mLeach, however, a national competitor's setup threw all that theoretical nonesense out the window... It is a good rule of thumb, no less, and has allowed me to make big bar changes without dramatically affecting balance.
