STR Prep - Suspension and Alignment
#281
Originally Posted by mron0903' timestamp='1333981454' post='21589802
What's a good ride height? I just installed my coilovers and did my alignment. Front i'm at 13.5" and rear is at 13.375. My alignment settings are as follows;
Front:
Camber -2.8
Caster 6.3
Toe 0
Rear:
Camber -2.6
Toe 1/4 total toe-in.
My concern is the car is sitting too high and could benifit more if I set it just a bit lower, but I also don't want to sacrafice driveability since I do drive the S 3-4 times during the week to work. The roads around me aren't the best. Any info would be greatly appreciated.
Front:
Camber -2.8
Caster 6.3
Toe 0
Rear:
Camber -2.6
I'd probably recommend lowering it at least a little if possible. I think you've still got more room to be comfortable on the street.
Right now I'm running just a little over 13" ride height on my daily driven s2000 on 800 and 700 lb/in springs, and that seems to work just fine. It's not as comfortable as stock but it's a good compromise for me. And I feel my car is competitive at any level.
To get a more in-depth answer than that you'll have to do some reading to see what different people's opinions are, and try it yourself.
Sent from my SAMSUNG-SGH-I717
#282
Originally Posted by IntegraR0064' timestamp='1333989421' post='21590389
[quote name='mron0903' timestamp='1333981454' post='21589802']
Front:
Camber -2.8
Caster 6.3
Toe 0
Rear:
Camber -2.6
Front:
Camber -2.8
Caster 6.3
Toe 0
Rear:
Camber -2.6
[/quote]
In front the tabs are bent up, rear is untouched.
#283
Originally Posted by mLeach' timestamp='1333983041' post='21589917
I guess those links at the top of the page have become invisible lately. Let me help you help yourself.
https://www.s2ki.com/...scussion-links/
https://www.s2ki.com/...-autocross-faq/
The general guidance is, don't go so low that you bottom out, and not too high, though it's better to error on the high side.
#285
We need to have a webinar.
The one thing that is a potential gotcha is that these are not sliding adjusters. They are rotating adjust which will affect caster and that is not legal. I had not thought of that until I saw Jason Rhodes quote.
Let me repeat it for the 4th time: THE TOTAL HEIGHT OF THE JOINT IS NOT AN ISSUE IF THE SHANK AND BALL ARE DIMENSIONALLY SIMILAR TO STOCK. ALL THAT HAPPENS ABOVE THE BALL JOINT IS IRRELEVANT TO SUSPENSION MOTION.
I hate to beat a dead horse, but what was the final verdict on the SPC balljoints?
#286
Doesn't have anything to do with legality but after less than 9000 miles the set of SPC offset ball joints I had installed on my STR car last year have worn out. Not sure if this was the cause but I was running at 12 3/4" ride height most of that time. I ended up ordering another set due to time limitations of trying to get the car ready for the Pro this weekend otherwise I probably would have went hard-race lower or possibly an offset upper bushing. When ordering the new set I asked Evasive if they had heard of premature failures and they said "No we sell a lot of those".
#287
I know lowering the rear adds rear toe in, at STR ride heights, per the toe curve vs ride height charts posted here, but does anyone know the affect on front toe for lowering the front? Does it also toe in, or does it toe out?
#288
Front:
Camber -2.8
Caster 6.3
Toe 0
Rear:
Camber -2.6
Front:
Camber -2.8
Caster 6.3
Toe 0
Rear:
Camber -2.6
#289
I think you can tell by the angle of the tie rods going from the rack to the hub. If the hub attachment point is lower than the inner pivot point then lowering should cause toe out to occur. If the outer point is above the inner point then lowering would cause toe-in to occur. In most cases I would imagine that lowering will cause toe out which is bad for inner edge tire wear.
#290
AP2 toe curve in the rear does not change in rebound or compression.
