StopTech Big Brake Kit
Old 12-17-2004, 09:07 PM
  #51
CrazyPhuD's Avatar
So are you still going to release a race only rear kit?
Old 01-03-2005, 05:21 PM
  #52
Stoptech's Avatar
Sorry for the delayed response. Short answer is yes. Pricing is TBA.
Old 02-11-2006, 12:18 AM
  #53
WyattH's Avatar
So we are confirmed that the standard 18'' GT7 wheel package from TireRack clears a Stoptech BBK without spacers? And can you run 215/245 tires, lowered, with slightly flared fenders, without rubbing??
Old 08-17-2006, 05:15 PM
  #54
trinydex's Avatar
i have a few questions, is the rear kit available? which size rotor is it using?
are the rear brakes for all model year s2ks one piece non vetilated? if so are there other kits besides the stoptech offering that enable you to run a vetilated rotor in the rear?
Old 08-21-2006, 08:00 AM
  #55
Stoptech's Avatar
Rear kit is available for sale. It uses a 322x22 vented directional rear rotor w/ a 2 piston caliper which also deletes the parking brake.
Old 08-21-2006, 09:25 AM
  #56
Ragingazn's Avatar
Originally Posted by cordycord,Oct 31 2004, 04:24 PM
I just bought a big brake kit from StopTech, and need to replace my OE wheels in order to fit them. Is anyone using this kit now, and if so, what wheels and offsets are you using?
Any help is appreciated.
Well anyways... back on topic... if you dont mind... how mcuh did you pay for that kit... I've seen some of the stoptech kits for the NSX and my are they beefy..
Old 08-21-2006, 10:36 AM
  #57
The Reverend's Avatar
Why didn't you make a parking brake caliper option? Seems to me you could have just built a wing off of the main caliper adapter fitting to attach a parking brake caliper off to one side of the main caliper.
I personally have had my brake hydraulics fail on a couple of cars so having a backup cable-operated brake is indispensible imo.
Old 08-30-2006, 12:56 PM
  #58
trinydex's Avatar
is there a way to retrofit a parking brake caliper or something?
Old 11-26-2007, 07:12 PM
  #59
trinydex's Avatar
is stoptech willing to help customize if someone decides to purchase these and run them with stoptech ventilated rotors?
http://www.eliseparts.com/shop/index.php?m...products_id=574
by customize i means give the necessary piston size numbers
Old 11-27-2007, 04:09 PM
  #60
honda9krpm's Avatar
That's good new. It's not a big leap but least a small step forward.
Are you able to fabricate some sort of drum brake system if you can't add another set of caliper for the E brake?
I got 2 workshops to extensively investigate this option for me and I still have my stock oem rear system on atm. I remove my ABS unit and have a 6pot Stoptech at the front. I think there is a lot of front bias and my car would lock up the front first if there is any water on the tarmac. I would love to have a bit more rear bias but still need the E brake. I hope you will have a solution soon.
BTW the front stoptech BBK is a lot lighter than the OEM smaller brake
Quick Reply: StopTech Big Brake Kit
