SPC Camber Joint vs J's Racing S1
Old 06-28-2011, 01:14 PM
  #111
LickyMYwalker's Avatar
Originally Posted by dc_s2k
Originally Posted by TubeDriver' timestamp='1309286383' post='20727921
[quote name='dc_s2k' timestamp='1309022088' post='20718785']
Got my car aligned with the J's S1 (blue) ball joints. The shop could only get -2.7 degrees of negative camber. Car is lowered 3/4"
I was looking for -3.5. Hopefully the -2.7 will work for me. If not, I'll be selling a very low mileage set of S1s on s2ki.
I bet you have a LOT of castor? Have them dial a couple degrees off the castor ans you will more -cam.
6 degrees. Not as much as I would like actually.
[/quote]
hm weird, i have -3 and im about your height...
Old 06-28-2011, 01:52 PM
  #112
dc_s2k's Avatar
Originally Posted by robrob
I'm pretty sure dc_s2k is lowered by about 3/4 inch.
That is probably about right. i had the car raised 1/4" from Skip's ride height because i couldnt fit my jack under it.
Old 02-07-2012, 05:06 AM
  #113
robrob's Avatar
I copied the following post to this thread since it kind of sums up my feelings on front end camber adjustment:
I melted the rubber boots off my first set of SPC ball joints so I replaced them after I put the brake dust shields back on to mount the brake vent hoses. I had to press the right front ball joint in and out several times to get the slot angle just right. When I went to torque the big top nut the whole ball joint turned in the upper a-arm hole. All of the in-and-out ( ) must have opened up the hole. I put the ball joint back into the right position and spot welded the ball joint to the a-arm. That was about 3 years ago and I haven't had any issues with it. If the upper ball joints need to be replaced I'll just go with new factory upper a-arms and add camber adjusters to the lower a-arm.
Even though I have been running SPC adjustable upper ball joints for 5 years I would have to recommend going with one of the lower a-arm camber adjusters like the Hard Race or J's over the SPC ball joints. Several people have had issues like stripping the big top nut, movement in the slot, and spinning in the mounting hole.
Old 02-07-2012, 05:56 AM
  #114
mLeach's Avatar
Caster is the devil.
Old 02-07-2012, 07:09 AM
  #115
dc_s2k's Avatar
Folks, if you are looking for more than -3 degrees of camber and are purchasing the J's racing offset ball joints, buy the red ones (S2) not the blue ones (S1). I maxed out at -2.9 with the S1. Both are very well made and in my opinion much more sturdy than the SPC product.
Others claim to get more than -3 with the blue ones, but that was not my experience on an straight (not wrecked) and lowered car.
Old 02-07-2012, 09:55 AM
  #116
//steve\\'s Avatar
^Maybe you weren't low enough?
My old s2000 had J's L1 joints which should provide the same extra camber but also be a roll center adjuster and at my ride height (About a finger gap between tire and fender) I had almost -4 just slapping them on. We had room to get more too.
Old 02-07-2012, 11:05 AM
  #117
psychoazn's Avatar
The old ones are red, and the new ones are blue, regardless of S1/S2.
Old 02-07-2012, 04:36 PM
  #118
Brian617's Avatar
^That's correct. I just installed the S2 camber joints and they are indeed blue. I just got aligned by Darin at West End, and I believe the front camber was definitely over -3* when I installed them, but he brought it down to -3.0*.
Contact Yasu at http://www.j-sracingusa.com/ if you need the S2s. He can get them from Japan in about 1 week. I couldn't find anyone else who had them in stock.
Old 02-07-2012, 09:00 PM
  #119
legend4life's Avatar
Why do you say that? I always read that more caster was good, adds dynamic camber.
Old 02-08-2012, 04:03 AM
  #120
dc_s2k's Avatar
Thanks for the clarification
helpslows2k
09-16-2018 10:57 AM
GoTuningUnlimited
84
02-28-2018 04:26 PM
tekstyle
04-29-2014 09:15 PM
RowdyITR
11-14-2007 01:05 PM
Quick Reply: SPC Camber Joint vs J's Racing S1
