Sparco Ergo Large - Will it fit?
I bashed that lip in too. You really only need like a 4" spot to fit the seat unless you want slider mounts.
Tut, I used 2 or 5lb i forget, hammer and swung for the fences
only takes 2 or 3 hits
Just curious...what are your dimensions? Height and weight? Does the large feel good for your size?
The seats wont fit without modification:
https://www.s2ki.com/s2000/topic/112...seats-part-ii/
Here is a list of halo seats that may fit with modifications. I have the Sparco Circuit II and I had to cut the vinyl on the tranny tunnel (no hammering needed), cut a hole in my door panel and modify the hard top. After all said and done, fits good and feels awesome!
Everyone seems to use waist size to gauge seat size, but that doesn't seem to be a good gauge for me, because when I look at the measurement for the seat width it's way too narrow, even for "large" seats. The Ergo is more square; it's doesn't get a lot narrower at the back vs the front. I could probably squeeze into a Ergo M at 340mm vs 370, but then the shoulder support would also be 60mm lower and the harness holes would likely be too low.
https://www.s2ki.com/...-seats-part-ii/
Boosted,
What size are you running?
ilovepinktaco
05-29-2008 11:59 AM
