Solo Nationals run order posted
I can't link directly to the run / work order thanks to the SCCA website's questionable decision to use dynamic content, but for the record, it's been posted to http://www.scca.org. AS and BS run in different heats, but AS runs fourth and BS runs fifth, so assuming good weather, the conditions should be fairly constant for each -- close enough to not throw off inter-class comparisons.
Anyone want to speculate on how the two classes will stack up? Many have speculated that the decision on whether the S2000 goes to AS hinges in large part on the Nationals results.
Steve
Steve
Run/Work Order
Tues/North - Wed/South
HEAT RUN WORK
1 SM2, DM, SML AS, ASP, FM*
2 FSP, ASL, BSL, FML BS*, SM2L
3 SM, ASP, DML SM2, ASPL, FSPL
4 AS, FM, SM2L FSP, DM, BSL, SML
5 BS, ASPL, FSPL SM, ASL, DML, FML
Tues/South - Wed/North
HEAT RUN WORK
1 STX, DSL, APL, F125L ESP, DP, EM*, BPL
2 GS, ESPL, DPL, EML BP, F125, STXL
3 DS, AP, BPL STX, GSL, F125L
4 DP, EM, F125, STXL GS, DSL, ESPL, APL
5 ESP, BP, GSL DS, AP, DPL, EML
Thur/North - Fri/South
HEAT RUN WORK
1 ES, FP, CSPL, CML EP, CSL, FSL, DSPL
2 FS, DSP, EPL CS*, CM, FPL
3 CSP, CSL, ESL ES*, FP, CML
4 EP, CM, FSL, DSPL, FPL FS*, DSP*, CSPL
5 CS CSP, ESL, EPL
Thur/South - Fri/North
HEAT RUN WORK
1 BSP, SSL, STSL CP, AM HSL, FSAEL
2 HS, BM, FSAE, CPL SS, BSPL, AML
3 STS, AM BSP, SSL, BML
4 SS, HSL, BSPL, FSAEL HS, BM, STSL, CPL
5 CP, AML, BML STS, FASE
* SOME COMPETITORS IN THE SAME CLASS WILL WORK IN DIFFERENT HEATS
The BSP listings include STU, the CSP listings include STS2
HEAT RUN WORK
HEAT RUN WORK
HEAT RUN WORK
5 CS CSP, ESL, EPL
HEAT RUN WORK
Originally Posted by jzr,Aug 26 2004, 12:36 PM
Run/Work Order
HEAT RUN / WORK
1 SM2, DM, SML / AS, ASP, FM*
2 FSP, ASL, BSL, FML / BS*, SM2L
3 SM, ASP, DML / SM2, ASPL, FSPL
4 AS, FM, SM2L / FSP, DM, BSL, SML
5 BS, ASPL, FSPL / SM, ASL, DML, FML
HEAT RUN / WORK
1 STX, DSL, APL, F125L / ESP, DP, EM*, BPL
2 GS, ESPL, DPL, EML / BP, F125, STXL
3 DS, AP, BPL / STX, GSL, F125L
4 DP, EM, F125, STXL / GS, DSL, ESPL, APL
5 ESP, BP, GSL / DS, AP, DPL, EML
HEAT RUN / WORK
1 ES, FP, CSPL, CML / EP, CSL, FSL, DSPL
2 FS, DSP, EPL / CS*, CM, FPL
3 CSP, CSL, ESL / ES*, FP, CML
4 EP, CM, FSL, DSPL, FPL / FS*, DSP*, CSPL
5 CS / CSP, ESL, EPL
HEAT RUN / WORK
1 BSP, SSL, STSL / CP, AM HSL, FSAEL
2 HS, BM, FSAE, CPL / SS, BSPL, AML
3 STS, AM / BSP, SSL, BML
4 SS, HSL, BSPL, FSAEL / HS, BM, STSL, CPL
5 CP, AML, BML / STS, FASE
HEAT RUN / WORK
HEAT RUN / WORK
HEAT RUN / WORK
HEAT RUN / WORK
S2K_Ryan
13
08-13-2010 11:38 AM
