Short Shifter
Short Shifter
I guy had a short shifter for the S on E-Bay awhile ago. Does anyone know who makes one and if anyone has one do they make much of a difference?
Thanks
Thanks
if you do a search there is quite a bit of info on these. From what I have read these are made for the JDM market, so they bend towards the right and are not very comfortable to use
For what its worth I have the C's short shifter but its on a UK car (as I'm in the UK)
It angles very slightly to the driver and of coarse is slightly shorter in its throw.
Gear changes feel quicker and once you've got the hang of the different feel its very slick, well pleased with the result it gives.
I'm surprised nobody does one for you guys yet? or maybe they do?
I've the C's on my car - RHD again. I've not found any more notichness, or 2nd gear grinds. The general shift quality is better than stock. There's one downside to the C's that I've found - it's harder to select reverse.
-Brian.
-Brian.
IMO you are better off with a countersunk knob. It shortens the throw without modifying the geometry, is cheaper, and easier to install. I suggest a Voodoo knob from Rick's.. you can even get a cheap one and sell it off with no problem if you don't like it.
I actually installed the C's kit on my LHD S. The throw is shorter, more crisp, and closer if that's possible. I installed it so that it leaned towards me and everything's fine. I do agree that reverse is a little hard to come by. And 5th and 6th will take some getting used to along with downshifting. However I am very pleased with the results not thinking it could get any better than stock
Chris
Chris
Slapasaurusrex
05-26-2018 03:26 PM
