Setup for a fast street/track S2000 - Part II Tires
#42
Originally Posted by Ludedude,Aug 17 2004, 11:07 PM
No, if you run a 225s up front you're going to need a bigger swaybar or you'll be spinning like a top.
205/245 no bar
225/245 need bar
205/245 no bar
225/245 need bar
#43
Originally Posted by drewchie,Aug 17 2004, 09:44 PM
while we're asking... what would be the right size setup for a totally stock setup? (no aftermarket sway bar either) I'm guessing I should stick with the 205/55/16 in front, but for the rear would I use the 245/50/16 or 245/45/16? With the latter, could I run a 225/50/16 in front without an aftermarket bar and not screw up the dynamics? Under $400 a set for CB street tires...
(Who in So Cal shaves tires? My razor's pretty dull)
#45
I have 225's in the front, 245's rear, and I'm not spinning like a top. Guess, I'm not pushing it enough. Does anyone know when the Saner bar will be available? or know another bar that is similar but less expensive than the Comptech?
Sri
Sri
#46
Originally Posted by drewchie,Aug 18 2004, 10:51 AM
Thanks...
OK, so 205s in front, but then which 245 in the rear the 45 or the 50 series?
#48
Originally Posted by drewchie,Sep 29 2004, 12:18 PM
Whatever happened to part 3???
BerlinaBayRidah
08-05-2006 09:36 PM
