Screw In Tire... Safe for track use after fix?
One of my new tires just got punctured w/a screw. I was planning on attending a track day w/these tires. I'm wondering now if its safe for track use after I get it patched? Anyone have exp w/this?
Thanks!
Thanks!
One of my rear S02's was punctured early in its life time and i had it patched by tireguy. Attended two track days and everything seems to be holding up great thus far. I'm going to Sunday's speedway event too.
The only way I'd try it was if the tire was patched with a true patch (unseat the tire, put a patch over the hole on the inside of the tire, sorta like patching a bicycle tube in reverse). Rebalance when done. If it's a plug, I sure wouldn't try it.
If it's in the contact surface (sidewall not damaged) and it's now plugged it should be fine, especially if it is a street tire, but that's an opinion without seeing the tire.
Take it to a tire shop, get it patched (as opposed to just $1.99 DIY-kit "plugged") and you should be good to go. The speed rating of the tire is technically invalidated once it has been repaired, but I am among the many people who have tracked patched tires without any problem.
Some people have reported tracking plugged (from the outside) tires successfully, but I would not advise doing that. And many tech inspection forms specifically disallow plugged tires.
In my case I went to Discount tire. Cost me about $20 IIRC. They installed a patch that looks like a little mushroom -- sort of a plug/patch thing. My screw was at a sharp angle, so they actually drilled a new perpendicular hole to install the patch/plug/shroom dealie.
Tire will have to be rebalanced.
I carry a plug kit to the track just for such occurences. Had it happen to me once at the track (tire deflated while on track, found nice nail sized hole in it in the pits) and someone there had the kit. Plugged the tire and was good to go.
Originally Posted by Razz,Mar 7 2005, 04:04 PM
Man I belive you guys are taking a risk.
A big risk.
A big risk.
