Saber bar... Clunking noise
Put on my saner front anti sway bar this morning,I followed a install write up here on s2ki to the T.(I think) then this afternoon I went to an autocross and noticed a clunking noise when I went over bumps.any ideas??? Its setto the softest seting if that helps
this is a common issue... its the end links. It doesn't really cause any problems, just makes noise. Sometimes tightening the bolts on the links helps. The way the geometry works the bar can't really slide back and forth even without the collars, all the collars do is save the endlinks from absorbing the side load
No issues from those bars... well except that they cost 4x what the saner does... The only issue I have had with the saner is a little noise but it doesn't bother me, and is definately NOT worth it to me to spend the excessive pricing of a gendron or ankeny
The noise has basically gone away after ordering the McMaster Carr endlinks. I hear it occasionally, but nothing that bothers me. The exhaust is significantly louder... My brother and I are going to try to source aircraft parts next time we replace bushings and endlinks on it. Yay for having connections.
