S2000 weight reduction
Old 01-01-2012, 08:04 AM
  #321
Administrator
krazik's Avatar
Interesting tip for those building cages. There is over 20lbs of roll structure in the a pillars.
Old 01-02-2012, 01:57 PM
  #322
SC_Highlander's Avatar
When I cut the windshield off of my autocross car, the total savings was 41 pounds. 20 for the glass and 21 for the frame. It's a stout, multi-layered bitch that ate through several sawzall blades.
Old 07-10-2012, 04:53 PM
  #323
slightly2ned's Avatar
Does anyone have the weight reference for cutting out the bowl in the trunk & replacing/patching up with a sheet of aluminum?
Old 07-12-2012, 08:14 AM
  #324
Administrator
krazik's Avatar
not much
Old 07-12-2012, 12:45 PM
  #325
DTP525's Avatar
Removed entire soft top/soft top motor/hardware. All of that is only 62lbs. I was hoping for 100lbs like I've read somewhere.
Old 07-17-2012, 10:04 AM
  #326
turbo8765's Avatar
Right, I was disapointed as well. When you eliminate the soft top and run a factory hard top you only lose 10 pounds. Although replacing the factory hardtop mounts with bolted in aluminum brackets will drop another 8-10 pounds.
My OMP halo seats (including mounts) are the same weight as the stock seats. When it comes to weight reduction on the s2000, there is no low hanging fruit.
Old 04-10-2013, 10:07 PM
  #327
Adam9638's Avatar
blast from the past, I say these and had to post them
http://www.evasivemotorsports.com/mm...w=&range_high=
Old 04-13-2013, 07:40 PM
  #328
Croc's Avatar
good to know that light windows exist for our car
Old 04-19-2013, 06:21 PM
  #329
smokeu2's Avatar
i was wondering if any of you guys still have all the ac parts and heater parts you took off to reduce weight lol because mine doesnt have it and i want to re-install both. if so, would you like to sale? thanks!
Old 04-20-2013, 04:00 PM
  #330
Ive got 2 ac compressors sitting on my parts shelf, but none of the other ac parts.
Quick Reply: S2000 weight reduction
