S2000 weight reduction
Old 05-05-2010, 11:06 AM
  #281
moogleii's Avatar
Looks like he has a half cage if his build thread is up to date.
Old 05-05-2010, 11:07 AM
  #282
Momentum's Avatar
Yeah, I'd like to know how you got that light as well. I don't even have a full cage or any AC/Heat stuff and my car is just over 2600... How much sheet metal did you cut out of that thing? I can't imagine it being possible to take another 100 + lbs out. The only things I could take off are the bumper bars, after that I would have to start cutting (more than I already have)
Old 05-05-2010, 11:23 AM
  #283
Antonov's Avatar
Your car is probably 70# more just because of turbo, Plus your wheel/tire package is probably another 20#, active rear aero another 5# or so, adds up.
I don't think rob has cut any metal, yet.
Old 05-05-2010, 11:34 AM
  #284
SC_Highlander's Avatar
My car was dead on 2400lbs at Nationals last fall, with a full tank of gas, but with the hardtop off.
Old 05-05-2010, 12:01 PM
  #285
rob.ok's Avatar
I have a mild steel steel half cage (and I'm using the heaver DOM because I was afraid I wouldn't be able to get the car under 2400lbs Oh well)
Anyways, nothing is cut yet. It's just fully stripped. Pretty much anything and everything I could remove, both inside and outside I took off and was pretty diligent about choosing light weight parts. As is, the car has full glass, AC / heat, and other minor accessories still like the air pump. Once I cage the car for W2W, I plan on cutting it up and getting rid of every thing!
-Rob
Old 05-05-2010, 10:24 PM
  #286
samsam5886's Avatar
Originally Posted by Kaolinte,Mar 2 2010, 08:43 PM
I will add that the windshield frame and windshield is 33 lbs total.
I would replace the windshield with a lighter one but I wouldn't touch the frame because it actually palys a big role in roll overs. I've seen many pictures of those windshield frames supporting the car in rolls and I think it's integrated with the frame of the car.
Old 05-19-2010, 12:50 PM
  #287
dan_uk's Avatar
removed some stuff today
03 door speakers + tweeters = 3lbs
radio antanae and wire loom = 1lbs
hood heat shield/padding thing = 1lbs
Old 05-19-2010, 12:59 PM
  #288
Momentum's Avatar
Just put some new springs and re-valved shocks on my car and realized its actually 2600 with me in it. Good to know I don't have 200lbs of lead hidden in my chassis somewhere
Old 05-19-2010, 02:48 PM
  #289
SILAP1's Avatar
I just removd my air pump and egr stuff , probly 10 lbs total of useless weight . Ill be back on scales soon wanna see if im close to rob .
Old 05-20-2010, 06:48 AM
  #290
Crackerballer's Avatar
Are you running a standalone to turn off the Cel light? I want to do this bad, I have my GT motoring kit (kept it just for the block off) but I don't want to throw a code.
Quick Reply: S2000 weight reduction
