S2000 weight reduction
Old 08-19-2009, 03:19 AM
  #231
TheBigShow's Avatar
only 10-15 pounds i believe, if you meant just removing motors and keeping the rag.
Old 08-19-2009, 06:18 AM
  #232
SC_Highlander's Avatar
Originally Posted by squirrels2k,Aug 15 2009, 12:19 AM
thanks. it is a 15gal cell.
Did you remove the stock tank through the floor, or drop the subframe, as the shop manual says to do it?
Old 08-19-2009, 07:42 AM
  #233
Administrator
krazik's Avatar
*eek* why would you put the gas tank so far back? It would have fit in the oem location and that would be WAY better for weight.
Old 08-19-2009, 07:55 AM
  #234
cuonice's Avatar
[QUOTE=krazik,Aug 19 2009, 07:42 AM] *eek*
Old 08-19-2009, 08:03 AM
  #235
Administrator
krazik's Avatar
i suspect they thought more about taking weight off the front w/o thinking about moment of interia and the fact that the cars weight distro is gonna change as you burn fuel.
Old 08-19-2009, 08:46 AM
  #236
robrob's Avatar
Keep in mind those soft top motors are way up high so removing them will help lower the center of gravity too. I'm running a hard top but I'd definitely give this a try if I had the soft top installed.
Old 08-19-2009, 12:47 PM
  #237
cuonice's Avatar
I suppose it's easier to build a fire-wall around the cell placed back there? Plenty of room to place it closer to the car's CG though.
On another note: I don't recall the soft top motors weighing much of anything. If you're a casual enough track day attendee that you still have a soft top, I don't think I'd be worried about the 8-10lbs.
Old 08-19-2009, 01:13 PM
  #238
rob.ok's Avatar
Not sure what the rational is but, all of the endurance cars that are being racing in the Super Taikyu series as well as a few others in Australia all have the tanks located in the rear of the car and they all have a firewall.
Here is a quick vid of J's Racing's new enduro.
[media]http://www.youtube.com/watch?v=aBuEJnOctsA [/media]&eurl=http%3A%2F%2Fwww.youtube.com%2Fuser%2Fumemot ojunichi&feature=player_profilepage#t=11
Old 08-19-2009, 01:19 PM
  #239
Yea, the motors by themselves are insignificant. Even if they're 5lbs each, if that's the only thing you are taking out, it's not worth it.
Old 08-19-2009, 01:22 PM
  #240
squirrels2k's Avatar
i removed the stock tank by lowering the subframe, replaced the subframe and then cut out the hump that covered the stock tank. i put the fuel cell in the rear for a few reasons... the 15gal cell that i have wouldnt fit in the stock location, i wanted to set the weight toward the rear a bit more just in case i decided to make the car a strict drag car, and i wanted it easier to get to the fill hole and i didnt want to run a hose to it. i did think about the weight changing as i used fuel but figured it wouldnt make a huge difference. ive driven the car quite a bit since putting the cell in and havent had any trouble with handling so far. it feels just like it used to before the install.
Quick Reply: S2000 weight reduction
