S2000 weight reduction
Old 04-02-2008, 01:26 PM
  #151
toofast4yalll's Avatar
^ Is that the only way?
Old 04-02-2008, 02:49 PM
  #152
Turn-R-Us's Avatar
I need to do the same.....as everything pertaining to the SRS is out except that pesty unit under where the stereo was.
Old 04-02-2008, 03:55 PM
  #153
tantheman's Avatar
This will shave some pounds.
Odyssey PC680 and tie down from Password JDM.
Tan
Old 04-02-2008, 08:30 PM
  #154
You don't have to remove the dash It just takes a little ingenuity (and some duct tape). A small ratchet with a 1/4" socket, a t30 drill bit, and a 1/4" drive drill bit extension. The space is very cramped, so I duct taped the t30 bit to the extension. Once you work your fingers in there and get it on the head of the screw, you can use the ratchet to loosen it. You will have to cram 2 fingers in to hold the socket while you loosen it. You can count on scraping a few knuckles on the sharp edges of the plastic around where the radio used to be. I had to use a magnet to fish out the back left screw, but the whole process only took 5 minutes once I found the right combination of tools.
Old 04-02-2008, 09:09 PM
  #155
SPECIAL-OPS-S2K's Avatar
nice! time to shave more lbs off of the S
Old 05-19-2008, 03:29 PM
  #156
rob.ok's Avatar
I'm going on a diet too
Stupid Tar is a real PITA
Old 05-19-2008, 05:04 PM
  #157
Turn-R-Us's Avatar
How much does that thing weigh.....I tried to get it out but didnt....what a PITA
Old 05-19-2008, 05:19 PM
  #158
S_nisen's Avatar
Not very much most likely. Remembering when I removed mine from my 5R Teggy, it wasn't must at all. Though, when going for an all out track car, you get rid of whatever is not needed and obviously that is not needed when the SRS units have already been removed.
Old 05-19-2008, 05:55 PM
  #159
S2KBLanton's Avatar
Dude, Awesome write up, I got some great ideas from it.
Old 05-20-2008, 02:36 PM
  #160
fly_S2K's Avatar
Dry ice and a scraper.
Quick Reply: S2000 weight reduction
