Rollcage tubing specs
Originally Posted by mxt_77,May 30 2007, 11:47 AM
Not sure why I thought chromoly was lighter.
Administrator
yeah exactly you used to be able to run thinner wall chromo and that is why it was lighter. But to stop people from having to build cages that cost 2-3x as much as DOM to be competive they changed the ruling so that the 2 metals had to be the same thickness.
-Ry
-Ry
Originally Posted by mikegarrison,May 30 2007, 12:54 PM
It's not lighter, just stronger. So if the rules allow using thinner walls or smaller diameters for the chromoly, the result is lighter. However, many of the rules have shifted to favor DOM mild steel rather than chromoly because it is less brittle, less sensitive to weld-induced heat tempering problems, and cheaper.
So, does anybody on here actually use chromoly?
Originally Posted by mxt_77,May 30 2007, 12:34 PM
I assumed it was structurally superior to mild steel.
1020 mild steel has a Brinell hardness of 121, 4130 chromoly has a Brinell hardness of 197. Brittleness is approximately proportional to hardness.
But it's been a long time since I had a metalurgy class.
Different heat tempering and such can manipulate this. In fact, that's what makes chromoly "hard to weld". It is very sensitive to heat tempering and removing the heat tempering because of the heat of welding. With chromoly, it's better to weld it up and then heat temper the resulting welded part. Hard to do with a welded-in roll cage.
[edit. oops! I meant that harder metals are also more brittle, generally speaking, but I originally wrote exactly the opposite.]
Originally Posted by mikegarrison,May 30 2007, 02:01 PM
Superior in what ways?
I can handle a cage that's "brittle", as long as the brittleness is only evident in a wreck that's so severe that I'd be dead anyway (due to extreme impact/G-forces/etc). However, I don't want a cage that's going to crumble, crack or fail in a scenario where a mild steel cage would simply "stretch" or deform, but still maintained enough integrity to protect me.
Edit... BTW, I didn't realize heat tempering was required for building a cage. What exactly does that mean, what does it do, and how does it work?
Administrator
If you want the safest, in recent FIA testing they've found smaller diamater solid mild steel tubing to be the strongest because it can stretch a lot farther before it tears. There was talk of moving to solid tubing for Rally cars.
-Ry
-Ry
^If it's solid is it still considered tubing ?
Where would one find the FIA findings and what are the odds US sanctioning bodies would recognize it if/when it was built?
ML Clayton
09-13-2008 03:48 PM
