Roll Cage while still keeping OEM softtop
Old 07-01-2009, 08:46 PM
  #61
Ben22's Avatar
[QUOTE=600rr_rocket,Jul 1 2009, 08:44 PM] Gonna bring this back...
Is there a manufacturer that makes a rollbar that can be deemed "safe" for BOTH track & street driving?
Old 07-01-2009, 08:53 PM
  #62
600rr_rocket's Avatar
[QUOTE=Ben22,Jul 1 2009, 08:46 PM]ED,
Let's do a group buy
Old 07-01-2009, 09:01 PM
  #63
Ben22's Avatar
I so will do!!! easy to do so, i enjoyed the treament. Shade in the paddocks and all..
I hope someone answers your question, i have been wondering myself.
Old 07-02-2009, 04:50 AM
  #64
dan_uk's Avatar
anyone know how much does the harddog bar weigh?
Old 07-02-2009, 02:31 PM
  #65
kinchu007's Avatar
Ed,
I would go with the HardDog...it's super solid. Here's some install pics
Tear Down: http://picasaweb.google.com/filip.craciun/RollBarPrep
Install: http://picasaweb.google.com/filip.craciun/RollBar02
Highlights:
Word of warning: the directions for the HardDog bar are wrong...because there is so little wiggle room for proper placement of the front reinforcement plates, they should be drilled for and secured first BEFORE you drill for and secure the rear plates...learned that the hard way and had to re-drill the rear holes (luckily it was only off by a few millimeters, but was still a huge PITA)
Oh, and the HardDog bar weighs around 45 lbs (depending on the configuration)...the stock roll hoops with all trim pieces weigh 46 lbs.
-Fil
Old 07-02-2009, 03:16 PM
  #66
dan_uk's Avatar
hey thats great to know thanks I was thinking I'd have to take the top out or do an exhaust to make weight with one
Old 07-02-2009, 03:41 PM
  #67
metros's Avatar
Kinchu - Did you seal inside the rear wheel well after you cut to place the mounting plates? From the picture gallery it looks like you sprayed undercoating but didn't do anything about the gaping hole you cut.
When installing mine I filled that hole with expanding foam, cut it even with the wheel well, and then sealed with around 7 coats of undercoating (enough to where you couldn't see the pores of the foam).
I too recommend the hard dog. It's a quality piece and you can keep the interior if you have the patience to trim interior pieces to fit around the bar.
Old 07-02-2009, 03:48 PM
  #68
kinchu007's Avatar
since there's a drain hole at the bottom of that "gaping hole" I didn't think it was necessary to fill it with foam
are you sure it's necessary?
Old 07-02-2009, 04:54 PM
  #69
metros's Avatar
When speaking with hard dog over the phone they recommended the expanding foam/undercoating. Even if there is a drain hole at the bottom I feel better keeping as much out of that space as possible.
I don't remember seeing a drain hole either. I can't imagine why there would need to be a drain hole there. Before installing the cage that's completely sealed IIRC.
Old 07-02-2009, 04:58 PM
  #70
kinchu007's Avatar
i'll take a pic of the drain hole thsi weekend...
Quick Reply: Roll Cage while still keeping OEM softtop
