Roll Cage while still keeping OEM softtop
Old 07-27-2009, 07:08 AM
  #111
//steve\\'s Avatar
Kinchu, what rail are you using for your seat?
Old 07-27-2009, 07:31 AM
  #112
kinchu007's Avatar
Buddy Club
Old 07-27-2009, 09:54 AM
  #113
//steve\\'s Avatar
Does your seat creak any? Also I know it looked awfully close to the floor. Does it actually touch or just hover above it a little? Also do you have the seat pitched back at all or is the front and rear sitting on the same holes on the rail?
Old 07-27-2009, 09:59 AM
  #114
kinchu007's Avatar
some creaks, but not much...it definitely touches...it's pretty upright so practically same holes (although there are 3 in front and 5 in rear so not literally the same holes)
Old 07-27-2009, 10:09 AM
  #115
//steve\\'s Avatar
I'm starting to think that It's creaking b/c it touches that small hump on the floor. I had my brother's seat in my car for a few days on the same rail and had no creaking out of it but it wasn't touching the floor.
I guess what I meant was is it the same number of holes from the bottom of the rails. I know the front has more holes but I'm pretty sure starting at the bottom they are at the same height. Like my seat is 2 holes from bottom up front but only 1 hole from bottom out back.
Old 07-27-2009, 10:13 AM
  #116
kinchu007's Avatar
counting from bottom to top, i have it in hole #1 in the front and hole #2 in the back...super low
and I think the creaking is from the rails themselves, not the seat touching
Old 07-27-2009, 10:19 AM
  #117
//steve\\'s Avatar
I was really thinking it could have been the rails. I've got the f1 spec rails and other than the front 5 hole bracket they look identical to the buddy club rails. The thing that makes me think it's not the rail though is that when I had my brother's seat in my car I had absolutely no creaking out of it and it was a cheaper seat too.
Old 07-27-2009, 10:49 AM
  #118
MADANT15's Avatar
Hmmm I should put some pics of my new setup up. I added a harness and diagonal bar since the last s2k challenge as well as a sparco pro 2000 with g force harnesses...
Old 07-27-2009, 10:50 AM
  #119
//steve\\'s Avatar
^Please do. How does the pro2000 fit? I was actually considering that seat too. Did you ever use that seat with the factory seat belts?
Old 07-27-2009, 11:38 AM
  #120
MADANT15's Avatar
Yes it fits, but it does rub slightly on the door depending on where you have it positioned. It worked with the stock seat belt, but i had to put a piece of wood between the buckle receptor and the seat in order to get the clip in there. It may rub on the center console, but I wouldnt know because I dont have one anymore.
Quick Reply: Roll Cage while still keeping OEM softtop
