Rear Sway Bar
Rear Sway Bar
I have an '02 S and I was thinking about taking the rear sway bar off for autox. I am on stock ap1 wheels, but I am running a non-staggered setup with four rear wheels and 225/50/16r's. Will I be able to give it a little more throttle in the turns? Or what will the effects be?
Not sure how itll be on stock tire sizes but its easy to check it out. Just undo a link in the rear on one side and make a couple of runs at the next event. Should take like 5-10 mins to take it off and put it back on.
Alright, thanks guys. How long does it take to unbolt one side? I'm just worried that I won't have enough time before my next run and I'll end up running with it the whole time.
Keep in mind if you jack up the car to install/remove the sway bar end link both rear wheels need to lift the same amount--preferably completely off the ground or the sway bar will be loaded. Could be a factor at the autocross.
No but seriously. You should try at home first to make sure that you don't run into a seized or otherwise difficult bolt to remove given that you have an 02. Also, you will familiarize yourself with the process and that could save time. I've done it between runs the one time that I tried it. It's easy when the car is on the ground... especially if you have a single exhaust and you elect to disconnect the driver side. I'd use a zip tie to hold the drop link against the bar to ensure that it doesn't get pinched some how while it's dangling.
i think you should try it. There will be benefits, the balance will be more reasonable and it won't oversteer as hard. On the other hand, you'll get quite a bit of roll, but I think it's worth a try at least.
It will probably suck to get off. Once you've done that, coat it liberally with anti-seize, then you'll be able to pull it off/put it back on in a couple mins tops.
