Rear camber problem
Rear camber problem
Took my car to an alignment shop, was shooting for
-1.25 camber front
0 toe
max caster
-2.0 camber rear
1/4" toe in
He was able to get -2.0 degrees on one side of the rear, but only -.5 on the other side. He said it wouldn't go anymore negative... Any suggestions guys? This is really pissing me off, paid $70 for an alignment and have only -.5 degrees camber in the rear.
-1.25 camber front
0 toe
max caster
-2.0 camber rear
1/4" toe in
Thanks for the responses... are the bushings easy to inspect without completely removing the camber bolts? I haven't noticed any obvious damage so far... they shop I took it to wants to put it on frame machine to check it out but the car has never been in a major accident to my knowledge (carfax is clean and only 1 previous owner). I'll probably just take it to another alignment shop before letting them touch it again.
No accidents while I've had the car and none reported by the only previous owner or carfax. Although it could have been in a minor accident and not reported...
