Race seats
#51
Originally Posted by trinydex,May 10 2010, 06:39 PM
seems there's lots of people here with recaro spg, what did you guys do to keep the seat from hitting the door? or does it just hit and it's not a big deal?
-Utilize a rail with side adjustment
-Shave down the outer wing
-cut the door panel
The further back you move the seat, the less it seems to rub.
#53
Originally Posted by modMonkey,May 10 2010, 10:07 PM
The SPG shouldn't hit the door, but the SPG Profi does. Eventually, the fabric will wear away from rubbing, plus it sounds annoying. I had a Taitec rail that allowed the seat to be moved closer to the transmission tunnel. This eliminated most of the rubbing. Your options are pretty much:
-cut the door panel
-cut the door panel
sorry buddy had to say it
#54
Originally Posted by Squirtle,May 10 2010, 10:14 PM
Steven's seat is locked in a position too close to the steering wheel for any normal sized individual
#56
Originally Posted by rob.ok,May 10 2010, 11:41 PM
I just made a wedge and track bar adjustment
#57
I run a Recaro Pole Position but really want to try and fit a SPG XL seat. now that my rollbar is in and some of the rear trim is gutted...mostly the piece that covers the soft to motors I think it would actually fit. I sit far enough back that my seat wings are past the end of the door so I don't have to worry about rubbing on the door. I also don't have the center glove box so no worries about blocking that off either. It's only 20mm wider at the shoulders so I figure 10mm each side. I think that plastic piece being gone just might leave enough room for it to fit....hmmmmm
#59
How wide are the wings on SPG? I'm kinda a big fellow so I'm looking at the Sparco Evo3. The base is 20.5 wide and the wings are 25.6 wide. Just wondering if I'll run into the door and or if I'll be able to open the center console.
#60
Originally Posted by trinydex,May 11 2010, 12:12 AM
has anyone tried to heat the door panel and push it in instead of cutting it. cutting is so extreme and if you could heat form a pleasant shape, it might not even look amiss...
