Race seats
#181
VERY interesting! Mine is a 2001. I'm 5'11, 33" inseam and like the seat pretty close so I'm surprised that yours works well at 6'2"! Do you have the stock carpet and trans tunnel covering? I do. Even with the rail out of the car, if you put the stock right rear bolt through the hole my rails can't slide over the bolt head. When the bolt is in it's furthest inboard position in the slotted hole the bolt will just slide inside the U-shaped upper rail. But to do that I'd have to beat the floorpan/trans tunnel to allow the rail to sit further outboard than it normally does.
Maybe it's a seat height thing? I have the rear side mounts in the 2nd lowest position and the front side mounts in the lowest position. I could see if it was raised higher then the receptacle would be lower than the rolled edge of the seat, making some of the issues go away. But I got this setup to get my head out of the soft top frame when wearing a helmet.
The buckle definitely sits well forward onto my right leg though, I can't imagine that could be different regardless of setup given the relatively short slots in the side mounting holes.
#183
Are you guys familiar with THESE seat brackets? PCI is in So Cal and I am going to drive down there, hopefully next week to test fit one in my car. Will be using my old Sparco Evo seat to test fit.
#184
Former Sponsor
#185
But for track purposes that would work for me. Once I find the right position I never move my seat, so I don't need sliders. I have to see it close up but it looks like there is a lot of adjustability sideways which should help in fitting many seats.
#186
Recaro Pole Position
Size 29 waist
5'8
135lbs
dd on these is awesome, love the extra crotch space. Car is a dd reason why i chose this over the Recaro SPG.
Size 29 waist
5'8
135lbs
#187
^ I would think the Pole Position would be gigantic for your size. I daily drove one for over a year and I'm 6' 235 and 36 waist and it was still plenty comfy for me. I'd think even the SPG/Profi would be a little large for you as guys up to a 34 waist say they can fit in that seat.
#189
With the Profi, it was still livable but a bit harder to deal with on a daily basis. Something you get used to after a while, passengers (read: girls) seemed to complain.
If you can find a Recaro RS-G, that would be optimal. Most comfortable and supportive seat I've ever had.
#190
