quick guide to over and under steer
Originally Posted by PedalFaster,Dec 13 2008, 08:31 AM
Just to be clear, I'm not criticizing you or your write-up -- it's great that you're contributing to the forum. I'm just saying that it's not yet in a sticky-worthy state.
my full writeup will be to follow shortly just got to work a couple things out of it.
Originally Posted by mzk784,Dec 13 2008, 10:08 PM
I got this table from a Yokohama Advan brochure, it pretty much on the same subject and summarizes a lot of things in a simple way:
I'm not trying to be a party pooper here, but at the end of the day the only universally correct advice for adjusting handling is "experiment with all of the variables at your disposal until your car's handling is to your liking". Understanding how and why any particular variable affects your handling is wildly more complicated than "increase this for more grip", which is why the oft-recommended book Tune to Win is 171 pages long.
^sure suspension tune up is way more complicated than this, but my car is fully stock except for the brakes and tires, so the only variable I could control at the track after I screwed up my alignment is tire pressure, and it did work well for me on a track day.
Originally Posted by ronnycage,Dec 14 2008, 12:19 PM
your wrong... you can always put different tire sizes on the stock wheels... you can always adjust the alignment. so as far as not actually modifying, a simple replacement tire setup and alignment can also do alot for you.
what I meant is that these tricks can be helpful at times when you can't or don't have control the rest of the stuff, that certainly doesn't apply to a racing team, but works well at levels of amateurs or weekend track day people like me.
Originally Posted by mzk784,Dec 14 2008, 12:32 PM
yes, you are right, but I couldn't change tires or alignment track side, I didn't have extra set of tires, and didn't have the tools for the alignment. I did change alignment at the shop next day, but instead of spending the whole track day with a car that is oversteering or understeering (slightly), a simple pressure tweak saved the day.
rickya
03-13-2017 09:17 PM
s2kpearlwhite
02-26-2009 12:21 PM
vapors2k
03-09-2003 11:55 AM
