Phase2Motortrend (P2M) suspension parts
Hi,
Does anyone have any experience with P2M parts? I couldn't find much parts review on google. The front/rear upper control arms and rear toe arms seem to be affordable.
http://www.phase2motortrend.com/category-s/278.htm
Originally Posted by AE_Racer' timestamp='1451397720' post='23838777
The ball joint area is totally different
Why would anyone mess with those when no one needs more adjustment for the rear and adding adjustment range on the front is more effectively done on the lower arm ball joint (or cheaply on the upper arm ball joint).
Adding camber by moving in the upper arm gives you more tire to fender clearance if needed. Also the SPC joints are known to slip and people have welded them to keep them in place. At $261 I believe these are cheaper than the popular j's racing lower joints, while having adjustability..
