oil presure/temp pick up locations?
Old 06-08-2009, 05:11 AM
bruce0293's Avatar
Default oil presure/temp pick up locations?
Guys,
I'd like to install both an oil pressure gage as well as an oil temp gage. Where can I locate a pick up point for both?
thanks...
~Bruce
Old 06-08-2009, 03:58 PM
Liquidsation's Avatar
You will need a "sandwich plate" or "oil filter adapter" that mounts between the oil filter and oil filter mount. That's the asiest way I found. Your sending units will screw in the that plate, www.glowshift.com, they have guages too but most any will work and they all have different size threads so watch that.
Old 06-09-2009, 04:25 AM
bruce0293's Avatar
Thanks for the reply, but I'll need to find an alternate means if possible as I have just recently started using a Canton oil filter, and there is no room left for an adaptor ;(
~Bruce
Old 06-09-2009, 01:43 PM
Nickamsweet's Avatar
other than the sandwich the only other method would maybe to just drill and tap somewhere? either that or try an oil flter relocation kit as well as a sandwich??
Old 06-09-2009, 01:58 PM
Shftat9k's Avatar
Any good places to tap? I do not want to drill into the block or anything like that. Preferably something that could be replaced if I were to decide to return it back to stock.
Old 06-09-2009, 02:13 PM
bruce0293's Avatar
Where does the factory idiot light pick up the reading from? There must be a way to adapt something there?
~Bruce
Old 06-10-2009, 07:47 AM
SPECIAL-OPS-S2K's Avatar
I bought a Greddy oil sensor sandwitch plate adapter and had it tapped to the common size for gauge sensors other than Greddy... its forsale if you need one.
J
Old 06-10-2009, 08:10 AM
How large is the filter? Can you not just swap it to a Honda filter and then use a sandwich? might be a much simpler way of doing it rather than trying to work around the filter's awkward dimension...
Old 06-10-2009, 08:18 AM
~Bruce
I'm was using a Canton filter AND the greddy sandwitch I mentioned... it works fine...
Old 06-10-2009, 08:57 AM
bruce0293's Avatar
I am using the long Canton filter. How think is the sandwich plate?
Quick Reply: oil presure/temp pick up locations?
