No rear sway bar= push
Granted, my car is a completely different animal, but when I ran no rear bar, I ran higher spring rates in the rear. I tried 700F/800R, 800F/950R, and 950R/1200R. I also had a saner bar on full-soft that the time, and ran my rear shocks firmer (in both compression and rebound) than the fronts.
Originally Posted by blackey,Jan 29 2010, 10:43 AM
The rear swaybar is worth about 100lbs in spring if you do the calculations.
Why not try going with an adjustable rear bar that allows you to go slightly softer than the stock bar in the back? (Not sure if such a bar exists) Or try the same approach with the front bar (adjustable to softer than stock.)
Think I'd throw the rear bar back in and go to a stiffer front bar and more negative camber up front.
Originally Posted by glagola1,Jan 29 2010, 11:47 AM
I like the idea of a softer than stock rear bar but I also like the idea losing that weight and have the rear wheels decoupled for maximum exit grip.
