More caster or more camber?
Is the camber gain not worth the increased steering effort of caster maxed out?
Or at let's say 6` of caster the camber gain is fine?
Just curious what everyone thinks.
Thanks
Mac
Thanks
Mac
so if at 6' caster I could use a bit more camber it's best not to get it with caster so straight line braking isn't affected.
I guess I don't understand the negatives to caster.
I did read something about corner jacking when the wheel is turned which hen said affects corners weights but when your in a corner. Oh! nevermind (lightbulb moment) it affects it in a negative way. The outside wheel lifts and the inside wheel drops.
So I guess caster is good to a certain point and becomes a negative affect?
Is that right.
BTW I ordered a few books so maybe I'll have less questions and hopefully not more.
Is that right.
Squeezer
04-26-2004 03:06 PM
