missing -1 degree of camber at the rear after crash
I hit a concrete wall pretty bad with the left rear. The frame was pulled out and the left rear corner had all suspension,axle etc replaced
I went to the same alignment place I always do and I remember the car would get -3.0+ camber easy but now it maxxes out at -2.4 on both sides?
I didn't change the ride height on coilovers after the accident
I could understand if the left was a bit off being crashed on that side but I can't figure how it lost camber on both sides?
Is your suspension set (rebound / compression) the same? This may seem a little silly, but if sitting higher because it hasn't "settled" on the shocks, the height could affect the alignment. That being said, I wouldn't worry about it if it's both sides.
The other thing that may have happened: one trick that people use to max camber (especially in front where it's limited).... they loosen the bolts in the suspension and compress everything with a jack before tightening to "offset" everything just a little bit more. Usually you can eek out 0.2-0.4 more just by virtue of a little room in the bolt holes to shift things a touch.
If the shop took out the rear subframe and other suspension parts when they straightened the frame, they could have done the opposite and cost you a few tenths of camber.
CKit the left side the shock was rebuilt but realy the right side was untouched as far as I know but I guess maybe something shifted
It is possible the shop's alignment rack was wrong before a while and they had it corrected but the front seems to be where it should.
I agree with CKit. Before I got the spherical bushings, I could tell if I put suspension arms on and cinched the bolts down before the car was on the ground. I'd get .25-.5 less camber out of a corner that way. I ended up using a floor jack under the lower balljoint to compress the suspension anytime that I put an arm back on the car. That let me cinch the bolts down tight without putting the car on the ground, and kept everything consistent.
