k20/k24 swapped s2000
Hey whats up s2ki...just posting up a little sneek peak of my k24 frank swapped s2000. Almost 100% finished. I have one more tune session for my nirtous tuning and some adjustments. I have some more black anodized skunk2 parts to put on the motor. Plus im going to change up the suspension setup and swap rims. Its sitting on ap1 wheels and stock suspension with lowering springs so its kind of a sleeper in my area. More in depth build thread with more pics and videos coming soon. Will be adding stuff i miss on this post...enjoy
K-tuned and Skunk2 are the main companies that made this swap possible.
*Numbers: not going to throw exact HP/torq numbers out because rumors on the streets but barely 300HP and over 200 ft/lbs torq on first dyno session.
Planning to extract more on second session and start my nitrous tuning.
*2002 S2000*
-Head
prb-1 2005 type s head
supertech dual valve springs
supertech retainers
supertech keepers
stock ports
drag cartel stage 4 cams billet 8620
Golden Eagle head studs
custom Magnus intake manifold
skunk2 72mm throttle body
skunk2 black anodized vtec solenoid
custom fabricated matched intake with velocity stack filter
K-tuned thermo heat shield intake manifold gasket
K-tuned thermo heat shield matched thermo throttle body gasket
-Block
k24a4 block with papers 28 k when purchased ..
13:2 supertech pistons
tsx 2007 rods new oem dealer
oem bearings all oem clearence
oem crank
oem 2009 tsx tentioner
spunteck chain guide
oem tsx head gasket 87mm bore
k20a oil pump with correct chain guides and chain and gear all from a z1
k20 aluminum oil pan
skunk2 black anodized timing chain cover
-Fuel
currently tuned on E85
ID1000cc injectors
K-tuned fuel rail
K-tuned adjustable FPR with Ktuned fuel pressure gauge
Aeromotive 340 drop in fuel pump
-Transmission
stock with stage 2 ACT clutch with custom ACT flywheel
-Cooling
Mishimoto radiator
-Custom swap parts
custom fab exhuast manifold with black heat wrap, ran straight into a dual N1 titanium tip invidia exhaust
custom Innovative motor mounts and tranny mounts
custom fab tranny adapter plate
custom ACT flywheel
custom modified ap1 engine harness
K-tuned alternator relocation kit
K-tuned swivel thermostat housing
K-tuned custom upper hose housing neck
water pump auto belt tensioner shaved off to clear Magnus intake manifold
-ECU/electronics
Haltech platinum series standalone
NGK powerdex AFR gauge
Yellow top optima battery
***all tuned by DKGOODRICH.COM***
-one of the best tuners in the KY/TN area. Car runs amazing. Plenty of torq. Great smooth linear powerband. Very happy with the results on only the first tune session.
[YT]http://www.youtube.com/watch?v=6e__ZsyT-0c[/YT]
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/484616_3540620276638_2089810121_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/562916_3550344239731_502785518_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/313614_3550341479662_926204923_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/215486_3553433916971_751409874_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/603523_3553370315381_240837576_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/260097_3658851712350_1135400955_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/546136_3674470262804_150904656_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/527536_3703712273836_229120888_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/427864_3691043157116_415452834_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/227898_3709896028426_1149342304_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/533641_3709895468412_1548455473_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/483379_3709896988450_507239820_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/223000_3709897628466_1469856091_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/225830_3709897988475_63003030_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/Facebook/Mobile%20Uploads/224411_3835578010397_1416794306_n.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/12063_4053806345969_2080946620_n_zps8d3ac04f.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/421084_3844574075293_939989213_n_zpsbbbb60fa.jpg)
![](http://i1023.photobucket.com/albums/af352/JDM346/s2k_zps133bf10f.jpg)
*2002 S2000*
-Head
supertech retainers
supertech keepers
stock ports
-Block
oem crank
-Fuel
ID1000cc injectors
K-tuned fuel rail
-Transmission
-Cooling
Mishimoto radiator
-Custom swap parts
custom ACT flywheel
-ECU/electronics
![](http://i1023.photobucket.com/albums/af352/JDM346/579215_3844573595281_1860473100_n_zpsa964285f.jpg)
riceball777
12-14-2013 12:30 PM
