J'S front roll centre adjusters with camber plates
someone correct me if i'm wrong, but…
#1 If you are lowered only 1" you won't affect roll center to the point that you will need roll center adjusters
#2 the red j's racing s1 offset ball joint includes RCA plate built in (blue original versions do not have roll center adjustment)
#3 what caster did you get, FWIW caster and camber are a trade off. On my CR with stock suspension I can get -2.8 or 7 degrees of caster but not both
#4 have you had your subframe re-centered?
2.i thought that the red ones was a new version of the blue ones!!!!
3. I get the same numbers with you on OEM suspensions. I agree with you, ''but not both''. But js racing says that you get +3degree camber from the OEM settings.
4. Please in light me!!
S2K VINCE (09-03-2024)
As for the uneven sides (fatter one side from the other) if I am not mistaken those new js rca's are the same on both sides, that make things more complicated.
