Indy V8 Honda
Old 11-07-2008, 01:04 PM
stocky's Avatar
Default Indy V8 Honda
..anyone every tried sourcing one?!
http://www.indycar.com/tech/engines.php
not an actual one maybe from previous season.
Not sure if this belongs here but I was ever amazed by the idea to put a
Honda V8 in the S and racing it.
Old 11-07-2008, 07:16 PM
markhs2's Avatar
I believe that this would be an incredible engine no doubt.
This caliber of engine is typically rebuidt about every or every other outing. No to mention the initial cost.
Try looking at the V8 built by Radical which redlines at 10,000 rpm and puts out 460 hp. This engine is used in their SR 8.
Radical makes a number of engines that can be purchased separately including the V8.
Hope this is useful/interesting
Old 11-07-2008, 09:53 PM
Asura's Avatar
And the Radical already comes with a sequential
Old 11-08-2008, 06:32 AM
stocky's Avatar
1st...I want a Honda engine
2nd...radical V8 engines tend to get on fire easily (seen in reality)
3rd...the radical V8 isnt cheap either and needs rebuilds too
you can chnge the engien specs so it has a little less output but will last way longer before rebuild
You can also buy Mugen v8 engines...tehy are around 30000 USD
They were used in Fomula 3000 series
Too bad Honda doesnt build production V8's which one could take as a starting base
Old 11-08-2008, 08:32 AM
CKit's Avatar
Aren't they coming out with an RL V8? Probably too big to fit in the S2000.
Old 11-08-2008, 10:13 AM
stocky's Avatar
too expensive too if its new...
any block would do it as long as its V8 and from Honda.
for the rest you always can get parts everywhere...
Bu tas for my information Honda never build a street V8 or did they?!
Old 11-10-2008, 07:36 AM
freq's Avatar
Team auctions happen from time to time. I've seen someone on here purchase a rolling (Reynard?) chassis. Engine will probably be harder to source as they are sometimes (most times) leased
Old 11-10-2008, 11:03 AM
ole p car's Avatar
If rylan can make 400rwhp out of a stock bottom end and have it last an entire racing season, just build the bottomend to highschool bolt on performance levels, kick up the boost and an extra 20% should be possible. (near 475rwhp) . thats near 550flywheel hp out of a little 2.2L
Old 11-10-2008, 02:06 PM
phoQ's Avatar
Personaly I would love to see it done, either in an s2000 or an nsx.
Old 11-10-2008, 02:10 PM
stocky's Avatar
Sorry but you are missing the point here
Quick Reply: Indy V8 Honda
