Hoosier R6 lifetime/wear?
how many session/heat cycles should I expect before the performance drops off and how many total?
I felt like they had 2-3 good laps after a warmup then they dropped off a bit I was running 32psi cold, 40hot.
I'm wondering if you do a warmup, one 80% lap then realy give them hell for one lap would be the best way to get the fastest time out of them?
I can't say much about r6/a6 on a s2000 but I have used them on a gt3 for a bit. Did you "scrub" them in? As in do a few easy laps to get them to temp then let cool all the way down when brand new? I used to run the old R6 at 39ish hot. I have been told the new ones like low to mid 30's. This helped my times and grip. I switched to A6 as they are almost ready to use after 1 lap and they don't wear any quicker. I have run them all the way to cords and still was pulling good lap times.
Administrator
Don't scrub, they're fastest when new. 1 warmup lap and go. I ran mine at 32 hot (285/30)
I could make 2 sets last me a whole season but they lost maybe .5-1sec after 3-4 sessions
The R6 starts to loose its life after 9 good heat cycles. After that you'll probably start to notice a lot more sliding going on. You need to get a tire temp probe and check the rubber right after a session to see what part of the tire is getting the hottest. Should always me about 10% hotter on the inside and then consistent the rest of the way out.
Administrator
Originally Posted by dan_uk,Nov 15 2009, 06:31 AM
do you notice they get a bit slower after 3-4laps ?
I'm wondering if I'm running them to hot, 32 psi hot seems very low
As for pressure, it is low for a street tire, but normal for a slick which the r6s have a lot more in common w/ a slick than a street tire. I've been running the tires for years at 32hot.
rather than doing a session, taking readings, letting it sit 40mins then going back out?
My .02.
