Hoosier A3S03 tire pressures
I've got some of the discontinued A3S03 tires that I plan to use at local autocross events. I'll be running 225 front and 245 rear with the Gendron bar. With the A3S04s I was running 42 front and 38 rear. I've heard the 03s like less pressure. Can someone recommend pressures for the A3S03? I was thinking 38 front and 34 rear as a starting point.
Thanks
Thanks
I think (always a risky manuever on my part) that most autocrossers measure cold. If running back-to-back runs, I'd think you'd bleed down pressure so it remains constant regardless of heat...
