Help on suspension setup !?
As you may know I am racing the S2000 on different events.
Lately we had a race on a track where 2 hefty bumps were on after the other (distance approx 10 feet.
The overall suspension setup is nod bad...I could easily foolow even the porsches through the corners but on these bumps my rear end started to "jump".
I am currently running 14 kg/mm spring front and back.
I can only adjust the "compression" on the dampers not the "pull"
My guess is that the "rebound" is underdampened versus the spring rate if you understand what I am saying
Shoul dI sendth dampers back to make the "rebound" stiffer or should I try a bit softer springs in the back (like 12 kg/mm)
The car's weight is currently 2511 lbs
Thanks for any help
Regards,
Yves
Front is perfect btw
Thanks for any help
Regards,
Yves
Edie_02ap1
04-28-2015 09:03 PM
