Harry's Lap Timer Pro
For those that have used this app, does anyone know how to get it to work on a pre-configured track, but going the other direction?
I tried using it with Streets of Willow going CCW. I see that the CW direction is one of the pre-configured tracks, but I'm not sure how to get it to work for CCW. Do I have to manually map each corner going CCW?
Not sure if this is the best way but it should work.
Rename current track to SOWCCW or something (click manage at bottom of lap list).
Then edit the start finish and any splits. Change the direction by 180 degrees. (Click first row below track name in laps list).
Then you can reload the default map again so you have both. Do not purge data when it asks you or you will wipe out the new track. It will have conflicts but I'm not sure what that really does...
3312DC
08-07-2007 12:26 PM
