Harnes Belts On stock Roll Bar?
Old 09-21-2005, 05:03 AM
Triple-H's Avatar
Originally Posted by CoralDoc,Sep 21 2005, 07:34 AM
Then how about me? 19 more days to 6 stars .
Congrats #62...
Old 09-21-2005, 05:52 AM
p0pe's Avatar
Get a CG-Lock... just picked one up and it works great.
Old 09-21-2005, 06:30 AM
pantyraider's Avatar
Is this because the stock roll hoops are too low/too weak? Has anyone tried welding on to the stock hoops?
Or, if you're short enough you may be able to sit low enough to clear the A pillar
Old 09-21-2005, 11:09 AM
CoralDoc's Avatar
The short version:
1. The stock roll hoops are too low to provide sufficient roll-over protection for most people.
2. There is no secure way to mount shoulder harnesses to the roll hoops or chassis without substantial modification to the interior.
3. The stock seats do not permit the correct use of a 5, 6, or 7-point harness.
Other concerns:
If you take the plastic off the stock roll hoops, you could hypothetically wrap the shoulder harness around each hoop, but you'd also need to weld stops onto the hoop to prevent movement of the strap attachment. Once removed, it is nearly impossible to re-install the plastic onto the hoop.
Holeshot121
06-05-2018 11:29 AM
TWF
04-20-2012 06:53 PM
PatentedS2k
05-15-2006 04:53 AM
stedge
09-17-2004 10:05 AM
kaufpw
03-27-2001 09:35 AM
Quick Reply: Harnes Belts On stock Roll Bar?
