Harnes Belts On stock Roll Bar?
I was thinking of hooking up a set of good belts and attach them to the stock rollbar (for now). This would be until I get an elda bar or another make hd setup. Has anyone tried this? and how do you remove the panel behind the seat to get access to the bar?
Originally Posted by payneinthe,Sep 20 2005, 09:32 PM
Do you think your neck's strong enough to support the weight of the car if you get upside down? If so, go for it!
Yes, you are better off with the stock belts. At least with the factory 3-point you can adequately duck your head. With fixed upper body restraints, you're stuck. No ducking for any reason.
You could get a sparco lap belt or a cg-lock if you just want to be more planted in your seat, but upper body restraints are a huge no-no without rollover protection.
Edit: Just noticed I now have 4 stars. Can't believe it's been that long. I need to get a life
Originally Posted by CoralDoc,Sep 21 2005, 06:23 AM
Here's a helpful FAQ to read: https://www.s2ki.com/forums/index.php?showtopic=143847
Great info, Thanks!!!
