Hard Dog Roll Bar
#31
I guess he could make it a bolt in but don't think i would ever want to remove it anyway so weld in is the way i would go. Yes that is installed so the only thing i do is make the interior fit when hes done. I'll take some pic's of it when its done. He said 2 days I will set something up with him for next week.
#33
Originally Posted by WynnS123,Feb 10 2011, 05:14 PM
Here's mine with a welded single diagonal and welded lower harness bar:
It appears the non-stock hoop compatible welded single diagonal and welded lower harness bar version doesn't protrude as far forward as the versions that retain the stock interior. Is this the case, and if so do you retain more (almost all?) seat travel with the "welded single diagonal and welded lower harness bar"?
The vertical elements appear infront of the bulkhead here:
Is it an illusion from the missing interior that they are further back here (and in Wynn's):
Thanks!
#34
Originally Posted by coldrsx,Feb 10 2011, 01:50 PM
Here is mine, love it, no issues with helmet or head banging (even without the maxis)
#36
the 200 works just as good from what i heard, what do you think? I've been debating on what wing to get, voltex, j's, apr 200 or 300... Might end up getting a replica one instead or something
#40
i just picked up a gtc-200... mostly for looks, but i'm having trouble installing it since all the hardware bolts they included were basically stripped... im going to try and get some replacement bolts asap.
