Hard Dog Roll Bar
Old 02-10-2011, 03:51 PM
  #21
chuhsi's Avatar
yes, that's a welded diagonal
a few of my pictures are below.
i cut my bulkhead in half so i could run the oem belt for the passenger. the bulkhead needs oem hoops for support. that's why you see the passenger oem hoop still installed.
Old 02-10-2011, 04:14 PM
  #22
WynnS123's Avatar
Here's mine with a welded single diagonal and welded lower harness bar:
Old 02-10-2011, 07:49 PM
  #23
innovation's Avatar
if you could take a pic of the rear view with the bar on and show him if the diagonal blocks the rear view. i think thats 1 of the concerns the OP had
Old 02-10-2011, 08:16 PM
  #24
Banned
wadzii's Avatar
Originally Posted by s2kobsession,Feb 9 2011, 11:43 AM
I have the double diagnal and couldn't be happier. Zero vision blockage and you can keep the glovebox - perfect.
this is what i'm looking for I think..
Does this bar limit seat movement at all and do you have a few more pics?
Old 02-11-2011, 04:22 AM
  #25
robrob's Avatar
I'm pretty sure the left main hoop will restrict the top of the seat some. If you're a full recliner you might have to adjust a little. Most people drive too far away from the wheel anyway.
Old 02-11-2011, 05:57 AM
  #26
clarkster009's Avatar
Thanks for all the pics! They definitely help. Does anybody have the welded seatbelt tabs option which allows you to retain the stock seat belts? Or any pics of that?
Old 02-11-2011, 06:45 AM
  #27
coldrsx's Avatar
^I have those on mine I believe... but no photos.
Old 02-11-2011, 06:52 AM
  #28
chuhsi's Avatar
you can see it in my last picture not being used. it's in the lower left corner of the picture.
Old 02-11-2011, 08:42 AM
  #29
cvedral's Avatar
I found a local builder, stokedmetalworks.com check him out robrob, i value you experienced opinion. He's local to me and came recomended by Irish Mikes. I am setting my 04 up for ttc with nasa. He will build and install the roll hoop diagonal bar and harness bar same as hard dog for the same price. I have to remove and reinstall the interior as needed.
Question i have is should i remove the stock roll hoops? If i do and keep the console i question the look of the interior. I still want this as a street car. ???
Old 02-11-2011, 12:40 PM
  #30
robrob's Avatar
I looked at stokedmetalworks.com's "work" pictures and it looks pretty good. Are they going to install/weld in the bar?
If you plan to put all your interior back in your car you should probably go with the Hard Dog bar, especially if you ever plan to remove it. The HD bar is pretty easy to unbolt and remove.
Quick Reply: Hard Dog Roll Bar
