First HPDE event
Old 10-14-2009, 07:26 PM
  #21
tinkfist's Avatar
Pleeease read the FAQ for this forum, https://www.s2ki.com/forums/index.php?showtopic=520674
You will find good info in there regarding you first day at the track as well as what to do regarding brakes.
Old 10-14-2009, 07:30 PM
  #22
Banned
QuadraJet's Avatar
I agree with Zdan. Just slap them on there and bed them.
Old 10-14-2009, 09:09 PM
  #23
WynnS123's Avatar
Originally Posted by ZDan,Oct 14 2009, 09:11 PM
Speaking only for myself, I've never had any issues just throwing HP+, XP8', or XP10 pads in the calipers, without replacing, resurfacing or even cleaning the rotors.
I think this is part of the reason why some of the guys in here say that XP10's aren't as effective as stock pads while cold. They recommend a rotor change with every pad change.
Old 10-15-2009, 05:05 AM
  #24
Banned
QuadraJet's Avatar
Well, it IS a track pad and not really intended to be a DD pad (though I DD on them). I change rotors once a year so, higher wear levels don't really matter to me. They work best after they've been bedded though, they'll eventually bed from normal driving. I tend to go out and engage the ABS a number of times after I install pads to get them hot. Not quite the bedding procedure that Carbo recommends but, a little like that.
Old 10-15-2009, 06:09 AM
  #25
WynnS123's Avatar
Yeah, they also recommend the correct bedding procedure to ensure proper performance. That's why I just buy them pre-bedded.
Old 10-15-2009, 06:25 AM
  #26
Banned
QuadraJet's Avatar
It's not clear to me what wear rate I'm going to get on the '2k. On the suby, I'd probably go through 3-4 sets of pads before I switched rotors. So, any kind of pre-bedding was pointless. I'm hoping the pads last longer now. My buddy has a '2k killing civic he tracks (I built it). He can do a whole track season on a single set of pads. He does have "Legend" brakes though which are bigger I believe than the S2K brakes.
Old 10-15-2009, 06:44 AM
  #27
GinoGT's Avatar
Thunderbolt or Lightning? Get Carbotech's... on my first time on Lightning (only third HPDE overall) I had horrible pad fade flying down the front straight going into turn 1. Thunderbolt will do the same thing to OEM pads, just that I didn't experience an "oh crap" moment because I knew to sandbag it going down the front straight.
Old 10-15-2009, 06:50 AM
  #28
scareyourpassenger's Avatar
I resurface rotors if the thickness measures out to be safe. I typically go through 3-4 pads per rotor before they need to be replaced. If you are ditching the rotors every set then I might be interested in your old ones
Old 10-15-2009, 06:57 AM
  #29
tinkfist's Avatar
Really? Lightning is the easiest on brakes track I've been to. If you were getting fade into turn 1, then you're braking too much
Old 10-15-2009, 08:33 AM
  #30
Banned
QuadraJet's Avatar
I don't believe in resurfacing myself. If a rotor needs to be re-surfaced, I replace it. My main fear on track is equipment failure at 130 mph (well that and someone dropping fluid in front of me). I'm pretty pro-active about replacing anything that even looks iffy. For example with heat crazing, if I can catch my fingernail on it, I normally consider rotor replacement.
For track use, you can't take any chances.
Quick Reply: First HPDE event
