Extended Wheel Studs
I just purchased ARP wheel studs. I was wondering if somebody would be so kind to direct me to a DIY thread regarding the install of the wheel studs. Or, if you could be so kind as to give me directions if they are not already available including removing the hub. Thanks!
Ryan
Ryan
Originally Posted by jlucas,Nov 9 2005, 05:19 AM
BTW, You'll need to do bearings at the same time if your going to pull your hubs off the car (the only way to get the studs swapped).
for the thread starter you will pop the 3 ball joints holding the knucle in, then press out the bearing and wheel hub, then press out the studs and press in the new ones. and then press in the hub and bearing again and bolt the knuckle back up to the car.
Originally Posted by SocratesDTC,Nov 9 2005, 08:35 AM
you cant reinstall the bearing. You have to buy a new one. A bearing can be installed only one time, then it gets damaged.
Well, this is what the manual says, and this is what i have learnt from a lot of friends who reinstalled the old bearings. after "x" miles the bearings worn out. That means : 1) you are lucky 2) S2000 has a special type of bearings Any help guys?
Originally Posted by pantyraider,Nov 9 2005, 10:30 AM
Some shops won't do the install unless you get the bearing replaced...
Ryan
Originally Posted by JDMwhore,Nov 9 2005, 11:29 AM
I reinstalled mine and have been driving on them for 20k+ miles without a problem.
