electronic secondary o2 simulator
I have an 05, been using a test pipe (invidia 70mm with built in CEL fix) for a couple of years - I drilled out two spark defoulers and stacked them and then put the secondary o2 in there.. haven't had any issues, even passed emissions (obd2 readiness check)
06+ are alot pickier but 00-05 are fine with a couple of defoulers
my 2c
my 2c
Caleb, please put me on your list for your simulators and let me know when you get them done (stevevetter@gmail.com). Also email me any web site you have or whatever for what you've done. I may be in the market for your EVAP simulator.
It's actually funny you bring that up as I just put an F22 in my MY 2000 with the MY 2000 CPU (will put in the 2005 ECM, but the seller forgot to send me the key at first), and I of course unhooked all the EVAP stuff. I throw codes for no air pump (plan on getting the simulator for that) but I've not thrown any other EVAP/emmissions codes.
It can take time for an EVAP related CEL to trigger as the testing criteria has to be just right (cool coolant upon startup, minimal temperature difference between engine bay and ambient air, and constant low-rpm driving). For example, I disconnected the purge valve on my integra and it took the ECU about a week of normal driving to realize it was missing.
Caleb
I just fixed my issue. I have an 07. Just some steel wool in the anti foulers and you should be good. Just make sure you use more steel wool if your car is throwing p0420 and less if it's throwing p0137. But if you've already tried it with no luck, then best of luck to ya!!
I bought the Izze Racing air pump simulator a while back from Caleb and removed my entire air pump system, installed the simulator and its been great ever since. No CEL. You just have to be sure of your connections and it will work as stated. for Caleb.
dsthez
06-24-2015 02:24 PM
