Done with R4S on the track
I had reported my disappointing results trying to use R4S pads on the front and switched to Panther+ pads. But being lazy I left the R4S on the rear since swapping those for every track event is a bigger pain.. and I incorrectly thought I would not have the problem in the rear.
Here are the R4S pads I just pulled off the rear.. obviously they cannot take the heat..
And they were not that far worn as you can see compared to a new R4S..
I will order some P+ pads for the rear tommorrow and will just use the R4S for the street for now.
Regarding rear pads, I put stock pads on that funny looking lightweight rear rotor I had installed, and kept the #3 'race' pads on the front Pinnacle system. No fading despite much late braking; UL did not mention any fade when he drove it as well, though the pedal tended to be lower on activation: Fresh stock rear pads not bedded?. The rear brake pads look fine from the sides, but I might take one off to be sure, espcially if I get the pads recommended by Brad for the rears.
As for the low pedal, I think there is still some air in the system, as I got much air out the fronts on the first bleed between LS days, and will see what the deal is next time. The brake pedal height for some reason also seems better after the drive home.
Originally posted by Sideways
Did you notice a decrease in function?
[QUOTE]Originally posted by Prolene
[B]Regarding rear pads, I put stock pads on that funny looking lightweight rear rotor I had installed, and kept the #3 'race' pads on the front Pinnacle system.
Originally posted by cdelena
It is hard to tell as just the rear becomes less effective.. you just use more pedal pressure and put a larger burden on the fronts. We know the stock pads fade but do not crumble so maybe that was your reason for a lower pedal. How about a full report on those pretty brakes.
Panther+ on the back initially felt hotter than the front, but stock pads felt less hot than front, but this makes sense to me. I switched to stock pads because I was concerned seeing the cadmium plating melting and being spit onto the rim with the back temps being developed. I didn't want to be potentially wearing those rotors out so fast. The pads that were meant to be on the rears were too thick, so I had to go with the P+ which I had with the sotck rotors.
ummm, SHEEEEEYOT...I just bought and put on new RS4's on mine for the Button Willow event this coming weekend because of all the positive feedback I have read. Now I am wondering if I have made a HUGE mistake. Granted I am sure I will not push my car nearly has hard as cdelena but none the less now I'm worried.
Should I be?
Should I be?
