Comptech Sway Bar owners, size of pin/bolt
Does anyone know the size of the pin/bolt used on the comptech adj sway bar? I was in the process of taking off the bar to put some new telfon tape on it and I noticed that my pin had sheared. I only have the top part of it left.
I want to go somewhere local and get another bolt. It would be easier if I knew the size.
Thanks in advance -- Tom
Are you running the first or second generation bar? The pins are different sizes.
If it's the 2nd Gen, the bolt looks like a specially machined piece to me, and I would be reluctant to use anything other than a Comptech replacement. The part that inserts through the bar is unthreaded. If you need something temporarily, the best thing to do is to remove the pin, go to a hardware store and specify the largest diameter bolt that will fit of the highest grade (hardness).
TubeDriver
11-21-2005 04:48 AM
ConeKiller
08-11-2003 04:15 PM
