Cold air without sacrificing aero
Do you have cut holes on your OEM hood? If so, your not venting any heat regardless (unless you are parked).
I would make a rectangular airbox to put in a big flat panel filter and then use a NACA duct to ram air it.
http://www.motoiq.com/MagazineArticl...r-Testing.aspx
You can probably buy a generic/universal NACA duct and mount it in the middle ala Dodge Viper style.
Originally Posted by josserman' timestamp='1391644749' post='23001117
i guess my concern is if I cut another hole how badly will the effect the air being forced out of the hood vents, result in less air directed to the radiator, and will it have any negative effect on aero?
This looks great!
Take a look at spdracerut's article, I found it very informative. There are/were a few threads that discussed hood louvres and vents and aerodynamics in general in this section.
https://www.s2ki.com/s2000/topic/877...t__p__20812917
"I have hood vents, but they are ONLY for looks, and actually increased my engine ccolant temps at the track. I have only 3 vents cut on the passenger side, and my coolant temps went up to 225F at a track day last year. Another S2000 owner at the same track event hit 250F with his hood vented with the 4 smaller vents near the windshield. "
If you look at the hood from the side, the back of the hood at the windshield is the highest point and the front of the hood the lowest. Therefore, when people cut holes in the hood, the leading edge of the hole is lower than the rear edge. So looking from straight ahead, the air has a straight shot into the hole. So air goes into the engine bay through the holes, creating a higher pressure zone in the engine bay behind the radiator. The higher pressure zone now in the engine bay behind the radiator reduces the airflow through the radiator reducing the effectiveness of the cooling system.
That's my theory at least and explains Gernby's results
So just a thought...what if i used the first hole as my intake duct into a closed box out to the charger. Seems that's the hole that would be sucking in the most air. Then added some sort of fin for the other 2 holes so air when moving wouldn't be forced in the them but instead could escape?
Obviously this is all crazy theoretical with 0 scientific backing but just logically it may make sense? On this route though should there be any concern to uneven downforce only having fins on one side?
