check engine light need some hellllllp.
just have a couple of qustion's went to track day this last past saturday try out my test pipe now my check engine light is on need to know the sequence to reset also what I may be able to do to avoid this again I here there is a o2 sensor replacement to trick the ecm in thinking the reading is correct any advice is greatly appreciated. mahalo joey
Administrator
Joey, do a search. I believe there's one fuse that needs to be pulled to reset the CEL. As far as O2 sensor replacements, I'm sure they exist but I couldn't tell you where.
